Does the 260EC engine hatch override have a fuse somewhere?
BilltheThird
Member Posts: 7 ✭
When trying to get in the engine compartment to reconnect the batteries on my boat, I couldnt open the engine hatch using the override posts. Ended up having to remove the transom shower unit, reaching inside to disconnect the ram, and lifting hatch with table mount hole. Lift motor tested good, and after reconnecting batteries, hatch opened and closed with dashboard switch as normal. Override posts still wouldn’t work. Is there an in-line fuse or circuit breaker between the override posts in battery switch compartment and the hatch motor? I couldn’t find one, but I didn’t take the battery switch compartment apart to check behind the panel. If it is fused, then it kind of defeats the purpose of having an override, doesn’t it? And an actual handle on the engine hatch would have been neat-o, too.
Best Answer
Cableguy Greg Member Posts: 5,069 ✭✭✭✭✭
Here is the battery panel on the 280EC. It does show 2 30A fuses, which should be behind the panel somewhere. Again, the 260's wiring should be very similar.
This is the wiring diagram for the 280EC's hatch. The 260EC is very similar, if not the same.
Andy
This time, I used a 750A brand new West Marine jumper cable box, and tried polarity both ways, just to see if I could hear any action at the hatch motor -no luck. The wiring diagrams are great. Kind of thought the simpler one was how it was set up, but the second- with the fuse- is what I suspected when it wouldn’t work. I’ll have to look behind that panel? I couldn’t find any blown fuses, 30A or otherwise. If they put the fuse underneath the panel, it’s double dumb.
