What is this junk on my filter???
Has anyone seen a filter this bad and know what this gunk is? It's like a dirt infused sludge. This was on my port cool fuel drop in filter. I change these every season and I have never seen anything but some discoloration in some of the pleats in the past. The starboard filter was normal. I have separate tanks. I'm thinking something must have gotten in the port tank or gunk in the tank let loose. I did run this tank really low at one point last season. Both engines were running great when I put them to bed in the fall.
On a positive note the paint in the cool fuel module appears to be holding at this point. Knock on wood... I am not looking forward to replacing those things at 1100 a pop. It just still baffles me they would paint the inside of the filter and pump housings...
I was going to say a mouse??
Dave
Good news is that the filter did its' job.
Also, saw the coolest thing on Cheadar....it is a boat wash for the bottom of your boat! It has a big brush, well several brushes and you pull up over it and it scrubs off the bottom of your boat...was not able to pull a link for it but the darnedest thing!
https://youtu.be/dv0QLPXG5nU
It did seem like fur almost. I wonder if something died in the tank. I have no clue how it ever would have gotten in there. The vent line is part of the fuel fill so again no clue how it would have found it's way in. Probably more likely is it got pumped in there from a fill station.
Upon investigating the cool fuel module it looks like the fuel enters the top front of the fuel chamber, spins around hitting the main filter, then exits through a small port at the bottom aft of the chamber. I gather the disc filter is the last line of defense.
I thought exactly the same thing, that looks like a decomposed mouse.
Consider yourself lucky! (for once!
