Cleaning off grease...
rasbury
Member Posts: 8,242 ✭✭✭✭✭
So trying to clean up from all my repairs...climbing in and out of the bielge things got a bit messy. Regular boat soap does not make a dent and concerned to use acetone to get it....is that safe for the gelcoat?
Best Answers
OptionsDream_Inn Member, Moderator Posts: 7,560 modIt should be fine as long as you wipe off with something else afterwards.
Optionsreneechris14 Member Posts: 3,134 ✭✭✭✭✭For smooth surfaces use wax with clearer.
Carb clean on a rag does wonders but wash with something else after2005 Rinker FV342 Pawcatuck river,Ct -
Options69fastback Member Posts: 951 ✭✭✭I would put a coat of wax back on that area, as the acetone definitely removed it.
