Hole in outdrive
Hello everyone, noticed this hole when prepping outdrive. What should I use to fill and should I be worried about water intrusion?
thank you in advance.
Patrick
06 Rinker 270
06 Rinker 270
yes that’s a speedo pickup hole
if you had a real hole it be leaking gear lube
06 Rinker 270
or the reverse situation
Ha, I was freaking a bit when I saw it. It must have been so clogged and painted over I never saw it as I sand and paint the drive every spring.
Think I can get it reconnected? Pitot tube does not work great either. Just replaced it last spring as well.
Thanks everyone!
06 Rinker 270
06 Rinker 270
https://youtu.be/QEL4THMZlZA
06 Rinker 270
06 Rinker 270
