Fix/Replace Cockpit Sink Faucet
I think it's finally time to fix my faucet. It's been getting very difficult to tighten it enough to not drip (yes, at some point it must've been overtightened). I would like to just replace the parts inside, but haven't found what it is. I also thought of just replacing it all, but haven't found it at GLS. Any ideas?
Hmm, not sure why the picture didn't post
https://www.amazon.com/Scandvik-10172P-Water-Swivel-Spout/dp/B003E1XXNI/ref=sr_1_104?keywords=marine+faucet&qid=1555951519&s=gateway&sr=8-104
I'd like to replace the guts for much less than $70. But now that I have what I think is the brand, might be doable.
https://www.scandvik.com/index.cfm?method=products_detail&productID=422
I'll now take it apart this weekend before purchasing to make sure it looks like the correct part. If nothing else, this may help the next person!
https://www.scandvik.com/index.cfm?method=products_detail&productID=575
is that wrench on the valve or the faucet itself? I know those valves can be in there pretty good as well.
The valve is threaded into the faucet body, and that's what I couldn't remove. Next time, I'll use a real box wrench instead of an adjustable wrench.
I'll take some pictures too. If you go to the website:
https://www.scandvik.com/index.cfm?method=products_detail&productID=145
you'll see in the pictures a detailed drawing of all the parts. It makes it nice if you only need to order a certain piece. Again, I need to double check that this is actually what is on my boat (I'm pretty sure, but I can wait another week at this point to make sure).
I had a leaking faucet a few weeks ago. I basically took the entire cartridge apart, cleaned quickly, pulled the O-rings and cleaned them and then put them back on, and re-assembled. Leak gone. Didn't have to replace anything. Just needed a little cleaning, that's all!
@Willhound - I may have to try the plumbers silicon grease on my faucet at home. It's a bit sticky when initially trying to turn on. I've replace the valve, but that didn't seem to help enough. I'll try the CLR on the boat sink as well.
The washer was $3.50 plus $7 shipping. It looks smaller because the old washer was totally flattened out.
Now it works beautifully and does not drip at all. Thanks @Dream_Inn!
Edit: I just ordered 2! What I don't like, I didn't see a price on shipping before buying. It just states "standard shipping rates", even after putting in credit card and purchasing. Even email they sent states it.
Edit: & I just received status from USPS with a tracking number that it was picked up & it's on its way!
I couldn't tighten mine enough to get the leak to stop. It was much more than a drip. Almost a continuous small stream. Anyhow, I cleaned mine and without ANY force of closing the tap it shuts off fine.
Why don't you guys just go to home depot and get this stuff? It's all there, for a few $ and you don't need to wait 1 week for delivery. This is not a "marine" faucet ... it's probably a cheap Pfizer tap or something.
Isn't there a shut off valve to the tap? This is not a big deal guys, take it apart, go to home depot, if they don't have the part, put it back together ... takes 15 minutes, not even. But to be honest, I'd get a shut off installed anyhow, which should be standard dimensions connected directly to the braided hose that connects to the tap. It'll take 1 minute to get that shut off in place.
I'm just saying, if you try to remove the washer before getting a new one, you're taking a risk. And don't measure the old washer to get a size for the new one.
I should have just ordered ten washers and sent them to everybody who needs one. The idea that I spent $7 for shipping is laughable. I mean, it's a washer.
LR - Agree - you should send them out to us
I agree it's a simple task to remove and maybe could've gotten at HD, but, mine still shuts off (barely) and isn't keeping me from using the boat. Much easier just to order correct part, and then only take a couple minutes next time at boat to change it. It'll be my Friday project and at least "milk" it enough to have a cold beverage!
