Hull Number on new Swim Platform
ruggerole
Member Posts: 162 ✭✭
So I installed the Rinker swim platform on my 232CC. This covered up the hull number. What would you recommend that I do with the number? I wroth the number with permanent marker under the platform where the original number would be. Should I do more?
Thanks in advance.
Two are required by fed regs. Not sure where Rinker places the second, and if they are in a consistent spot on each boat. Someone else may have better info on that, or you can call Rinker and ask where they put the second set.
For those who are unfamiliar with the requirement, here's the info:
but ye you can etch it on the underside of the Swimplatform starboard side.
I'm having a stainless tag made. Will attach it to the hull just under the platform.
Thanks all
Andy
Andy
