Trim up/down
ruggerole
Member Posts: 162 ✭✭
Is it the trim pump solenoid valves?
It will go down but not up. Only clicks. What should I look at to fix?
2001 Captiva 232, Bravo 3
Thanks
(Now attached)
OK, I ordered new solenoids. Should be here soon. In the mean time, I did the jumper deal. Both up and down works just fine.
At the throttle, down works all the time, up once every 10 or so times. I can hear the clicking at the pump so that tells me that I am getting a signal. Is this the solenoid or low battery?
But one thing has me confused.
"Zero Ohms Reading (Full Continuity)-Fuse OK.High Ohms Reading (No Continuity)-Replace fuse."
I was always taught that a zero ohms reading means no continuity so fuse no good. A reading shows the fuse is intact and offering resistance. Am I wrong?
0 volts across the fuse means no potential difference, IE fuse is intact.
When you check a good fuse, the current from the meter battery flows through the fuse making the needle go to the right all the way - 0 ohms resistance to the flow of current. If you check any fuse or switch, a good fuse or switch in the on position will show 0 ohms. A fuse or switch should have no resistance (ohms) at all.
So yes - nothing from meter on ohms setting means open circuit, test by touching the leads together and it will swing right. (If it still doesn't you may have a dead battery in your meter or bad leads)
D'OH!
