Power steering pump
So, couple of things...first, there must be a high rate of theft of power steering pumps as they are a mother *^$($% to get off!
As soon as I took the belt off, the pulley has a lot of wobble to it so I assume what ever is there for a bearing is toast. I will do some research and see if I can track down the GM pump and if not will take @212rowboat up on his offer for a used pump off a motor I believe he removed.....anyone know where to start with that? These parts places when you walk in the door if you can't tell them a make and model of the part your looking for then they are just lost and I guess I get it.....if they had that much knowledge they would be working on stuff making better money than selling parts.
One thing I did not like that I saw there is a magnet it looks like in the reservoir and it did have some metal pieces on it-could that be from the bearing and go all the way through the system and get returned to the reservoir through the return line? Have no idea what is in the rams but I sure am hoping that is not where the metal came from .....don't know if you can see it in the pictures...there was one piece probably a quarter of an inch long....a little thicker than a piece of thread...
Anyway, any one know how to track down the pump at the auto parts store?? I hear they are pretty cheap!
Me too - no gen is a boon in a way as it leaves a nice place to site and do that otherwise i'd have been laying over the engine working upside down - as I just did with the water pumps.
Good luck - any questions post here with photos, see if it reminds me of anything of note.
I would imagine that given the time of year, Al is up to his ears trying to get boats ready.
You can turn the wheel with the motor off? Doesn't it tighten up once you lose pressure and turn the wheel a couple of times?
Boat ran good otherwise...and oh, it is leaking power steering fluid a little bit still and I can't seem to find where that is coming from.....does not seem to be from the pump. When I pulled the plug out, probably 2 oz of fluid came out...
Can't seem to upload a video?
On the flat, muffs and all, fire it up and turn it to lock both sides over and over smoothly and slowly with cap just resting on threads.
You may have to top it off when you're done.
That ticking sounds like you're describing cavitation in pump.
