Mid bilge water
2002 Rinker 342. I keep getting, what I feel is a significant amount, of water in my mid bilge. I have checked the shower sump, behind the shower cuddy thing, toilet, all the ac lines, anchor locker etc. I finally pulled the covers to the fresh water and holding tank. I don’t believe it is a fresh water leak and don’t see one anywhere. Pump doesn’t ever randomly run to pressurize and this amount of water would cause it to run at least a few times a day to pressurize.
It probably pumps about 3 gallons or so a day I’d say but that’s just a guess.
However, now comes the scary part. On the black water side, I notice through the tiny hole, which they make difficult to see, what appears to be a leak of some sort running very slowly but the only place I see water. I don’t know how to check the tank or see if it’s coming from somewhere else and just under the tank.
I guess the the real question is, if the black water is leaking, would it go to mid bilge or rear engine bilge? The water in the mid bilge seems nasty but not black water tank nasty.
Any my help is appreciated.
Check the air conditioner. Maybe a leak from the pump or supply line, or just condensed water from the evaporator.
Is it a steady amount regardless of rain? That would rule out a leaky rub rail.
Next time you leave the boat for a few days, mark the level of the water tank before you leave. If it doesn't change, that rules out a fresh water leak.
Turn off the fresh water pump and AC. Get a wet-dry vac, remove all water from the mid-bilge, wipe dry with towels. Turn pumps back on one at a time and see if you're getting water.
Empty the holding tank, don't use it for a week and see if the leak stops.
boat under cover would/should eliminate water from rain. The engine area bilge is separate from the mid berth bilge.
You should be able to see from what direction the water is entering the mid bilge. There are drain holes in the stringers to let the water in there from the sides. Have you checked the condensate pan/drain/tube from the AC? If plugged or leaking it will drain to the mid bilge.
You can try shutting off the AC for a few days and see if the water stops filling.
Good luck, will be curious to hear the out come.
May this can shed some light on whats back there.
Also: are you connected to city water?
