Backing in slip
cls10105
Member Posts: 352 ✭✭
This past week we took the boat out and it was great trip. Until it was time to bring it back to the dock. Oh man what a pain. Truly one of the hardest things i have tried to do. Between the swimplatform and the size of the boat it was horrible. I should have got a canoe or kayak...lol
cruising on 6. tw0s
You will get the hang of it with time but depending on conditions, closer quarter maneuvering will never be easy.
Last weekend went to a neighboring Marina and the current in the harbor was awful. It took me 5 attempts to learn the current and figure out how to approach the back in
Practice practice practice is all I can tell you. Have fenders out...get a docking pole your crew can have on hand if needed. You will get it.
With my single and the high top and radar arch on the 270 it can be a handful sometimes. I back in, so gentle throttle, but I rarely power it all the way in. I just get even with the end of the finger dock then jump off and guide her in by hand. Usually enough rear momentum to get it right in with little effort.
Little tough maybe to do that on a 342 though, so yeah, practice. Even if you pick a calm bay and just noodle around in reverse for a bit you'd be amazed how quickly you can get a feel for it.
For example, if I'm coasting in neutral, I can turn the wheel hard over and use the outdrives as rudders to rotate the boat. (It works only if I'm making way and there's water flowing past the drives).
Or, with the wheel hard over, I can bump the throttle on the outside drive (forward or reverse) to push or pull the stern sideways like a stern thruster. I basically put the bow where it needs to be, and use the drives and wheel to kick the stern to one side or the other as needed.
Throttle? In a cross-wind, my boat won't spin without throttle. She has a lot of sail area, and doesn't have the big torque of diesels. If the wind is faster than 10 mph and my engines are at idle, the engines won't overcome the wind until I apply some throttle.
sterns usually rotate the boat way off center and arc when turned.
but either way practice pays off
Once you get really good at it, like @LaRea said. You can add in the wheel for all kinds of fun. I love a good challenge (without bow thruster usage) and walk the boat sideways (I usually use the wheel and "outside" drive. It takes back and forth with turning the wheel, but you can actually keep the boat from moving forward/aft and walk her sideways.
Practice is really the key...I like to come in my marina at dusk...traffic and winds are very low then. When I get close, I maneuver around the various fingers and slips without the steering wheel, just engaging the drives. I pick a spot and go to it, then I back out, turn around and do it backwards. I do this all over the marina, its my way of practicing and keeping sharp.
The 342 is sooooo easy to handle, it responds very well to drive engagement. Except for real windy or strong currents, I can slip my boat all by myself.
i feel good about it
https://youtu.be/XHGGj6ZnDGs
