Help with a steady alarm and no start
Hi everyone. Thanks for any and all help. I have a 202 342 with 5.7 mags. We had the engines warming up to go out and got a steady alarm for the starboard engine. No big deal trace that to a bad temp sensor. Now what is has turned into is a delay of about 30 seconds for the beep and fuel pump to come on. Then the alarm is on steady the fuel pump will not turn off after the normal few seconds and the engine is a no start. I am trying to find out how to clear the codes and would they keep this problem. I did a bunch of testing and it goes back to the ecm. Swapping it to the port side the problem follows it. Any thoughts on this. I have my own but not sure about this 555 ecm clearing. Thanks for your time.
I had issues last year with repeating 2 beeps that was an IAC but for some reason had a stuck relay for the fuel pump - a tap and it dropped off. Replaced then last cruise of the year one double beep again, found the master relay was faulty (per the code) now replaced also. 5 hour trip to home port yesterday no issues.
So turn the key, wait the few seconds where it should drop the pump and then tap the top of the relays, see if they drop off. If so that would be starting point 1. But you still have to clear codes so having the ECM read is important.
Stand corrected in part - the Block Coolant pressure alarm I created when disconnecting the sensor the other day is not "sticky" so cleared and the app allows the notification to be cleared also. There will be some that are "sticky" you'll need the right tool for.
