Wiring run for windlass on a 2004 270
I've upgraded the windlass to a Lewmar pro 1000, according to my electrictian I need to upgrade the wiring... anyone have any idea where the wire runs and how hard of a job it'll be to run thicker wire through it? Kind of regret not just going with the smaller one!
Hope you have better luck.
I did just use the stock wires for the last half of last year... but the electrician says I'm using wires that are DRASTICALLY too small and will end up burning up the boat someday.
Showed it to the electrician friend, had him come check what AWG factory installed, and luckily it's 8AWG so assuming the boat is 30 ft (really it's probably more like 25 ft from battery to windlass. It looks like 8AWG is well within the rating. Thank god!
So I went and searched for something more detailed, talking about the 1000 instead..
all I can say is "doh!"
I may be selling the 1000 and getting a 700..
This one is from this PDF:
https://www.jamestowndistributors.com/userportal/pdfs/Lewmar/Manual_Pro_Series_Fish_Windlass_English.pdf
The other screen shot is from:
https://www.lewmar.com/Lewmar-Files/Manual_Pro-series-fish-manual-G3_B10414%20iss1.pdf
There's a 3rd version here:
https://www.lewmar.com/sites/default/files/sites/default/files/Pro-series-fish-manual-G3_B10490%20iss2_0.pdf
So I dont know which one to believe here, they all look like lewmar manuals to me.. Wonder if the first version had people burning up boats. Either way - really not looking forward to trying to run 4 AWG line through the boat, sounds like the electrician was right!
4 AWG is 25 sq.mm. of copper. The boat already has a run of 8 AWG, which is 10 sq.mm., so you could just add a parallel run of 6 AWG (16 sq.mm.) and gang them together. The total area would be 26 sq.mm.
You'd need bus bars for the connectors, but the wire would be $2/ft instead of $8/ft, and much easier to work with.
https://www.amazon.com/Welding-Battery-Flexible-Terminal-Connectors/dp/B01M8QTJ3O/ref=sr_1_3?keywords=25+ft+4+awg+marine+wire&qid=1558401310&s=gateway&sr=8-3
Or this one:
https://www.ebay.com/itm/Marine-Wire-4AWG-6AWG-8AWG-Black-and-or-Red-UL1283-1231-BC-5W2/152012201484?var=451208425701
Comes out to 1.58/ft
Will complete the install tomorrow, including this wireless remote (already tested 100% works):
https://www.ebay.com/itm/Anchor-remote-windlass-wireless-switch-boat-sail-trim-controller-boston-whaler/232009695848?hash=item3604db0268:g:7-EAAOSwiMRbCKzR
