Wonky tachometer question...
2007 350EC, twin Merc 350 MAGs. Starboard tach is bouncing a lot. Tried tapping the gauge, think it might be a bad ground. Where would I continue to look for this ground (or the sending unit on the motor)? I have pulled the dash and everything is very clean, no corrosion. Pulled the connectors on the gauge, everything is very clean and good.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
Faria tachs are known for that. As aero3113 says, try moving the pin in the back and forth, and put it back in the right setting, then see if it settles. Ohterwise, get yourself some better gauges!
