2003 312 starter just spinning
The starter is constantly spinning regardless of key position. The only way to stop is to turn the batteries off. I’m guessing problem is with the starter/solenoid. Just wondering if anyone else has had a similar problem or could advise me before I tie myself in a knot and attempt to get the starter out without removing the engine that has been out twice in the last month. I knew I should have just changed it out. Such is my luck!
from there you can trace to figure out what failed.
if it’s actually turning over it could be switch,
relay or starter itself shorted
