ProMAriner IsoCharge
SeaShift
Member Posts: 27 ✭✭
is trying to install a pro mariner isocharge in place of the battery isolator that failed.
The new new unit needs an ignition controlled power input. Any idea where to find that one in the engine compartment of my 312 or do I have to go back to the helm. I don’t know why it seems so foreign to me. On a car it’s simple.
Any advice would be greatly appreciated
thanks
thanks
Did you install the ProMariner? What do you think of it?
I was on shore power all weekend, but the house bank went down to 9 V and the charger was acting all crazy. This is a high-end Blue Sea Systems charger with a digital display. It would say bank 1 was pushing 50A for a few seconds, then zero, over and over -- and it wouldn't charge any of the batteries.
With the engines running, the alternators wouldn't charge the house bank, so that was my clue to remove the isolator and check it as @dwmackenzie described. It tested fine ... around 0.5 volts from each alternator pin to each battery pin, infinity in the other direction, and no shorts to the case. Then I bypassed the isolator and connected the charger directly to the batteries, and the charger works normally. Best guess, maybe the isolator was damaged by a power surge in Thursday's storm.
I couldn't find a diode isolator locally, so I ordered the ProMariner box. I installed the ignition leads from the helm today so I'll be ready when it gets here.
@seashift -- my boat has digital throttle and shift (DTS), so just I tapped into the bus bars at the junction box behind the helm.
http://rinkerboats.vanillacommunities.com/discussion/10106/installation-notes-promariner-proisocharge-battery-isolator
