5.0, 305 merc program
JFDee
Member Posts: 27 ✭
Just bought a 2001 242 rinker with a 5.0..305 merc with a alpha 1 out drive. Ran great at sea trial but smelt a little gas in the engine compartment. Brought it home, washed the hull with dish soap and was bone dry. Filled tank with gas, went for a run and boat Boggs down, sputters. Boat runs and starts great, only Boggs down when giving her.bilge pumps out gas and a milky white substance. Does anyone have a suggestion where to start as I'm new to boating and already want to sell.
Fuel in the bilge? #1 dont run the boat if you have fuel in the bilge... serious explosion Hazzard.
Check all fuel hoses for leaks...and also oil lines / pan for leaks.
You're new to boating, so maybe you don't know the danger. Gas fumes are heavier than air. Unlike with a car, fumes will accumulate in the bilge, and a spark can create a major explosion. Even a small gas leak can be deadly because the explosion can throw people off the boat.
Park the boat until you find and fix the fuel leak.
also take note the fuel line vent likely vents into the bilge... which i think is kinda crazy but i don't have a better solution either.... some folks overfill the tank and it comes right up the fill tube and right down the vent line. keep that in mind while filling.
yeah, it runs adjacent/parallel to the fill tube. bilge is not the term i should have used though... engine compartment is. the tube open adjacent the cap under the glass and protected from intrusion of debris. it is on mine, anyway. i can't say that i've purposely removed a fill tube on any other inboard, though.
https://perko.com/catalog/fuel_system_components/158/sealed_ratcheting_cap_fills_with_pressure_relief_for_1-1_2%22_hose_-_angled_neck/
As always, run your blower minimum 3 to 5 min's before starting up. And it doesn't hurt to give the exit vent a sniff too before starting up.
Many of us will also open the hatch when starting for the first time of the day. A good opportunity to check engine oil dipstick and do a visual check on other fluid levels like drive and trim fluid and just the general state of things.
https://www.youtube.com/watch?v=lpFjkL1YvBI
Get to know what "normal" smells like for your engine room. If the odor is anything other than normal, investigate before starting up.
There is (was) a third hose zip tied to the fuel inlet/vent that followed it almost to the cap and then bent toward the helm in the routing passage between the top and lower shell/hull. It ended about a foot after the bend. It went atop the tank toward the bow, but wasn't (or at least wasnt well) connected to anything. I have always left it alone believing it a vent.
I'm thinking perhaps the prior owner used it to route wiring possibly? There was, when I bought the boat, a cooler under the aft seat that was drilled and a couple wires coming through side near top. I saw it for what it was: a makeshift bait or live well missing its pump/aerator (sp?). I pulled the wires straight out of it, and there must have been 15~20' of it... I bet you all a dollar it went through that hose at one point and to a rocker switch at the helm...
So I'm relieved. Ive never really thought about it until now and y'all talking about venting...
