2003 342FV shower sump problems.
MojosBoat
Member Posts: 102 ✭✭
Shower quit draining so I checked the sump and sure enough it was working. The pump is bad. Switch is good. Pulled the whole sump out and noticed the inlet neck is cracked. Went and bought a new sump from West mating. No good. It will not fit between the stringers. So now I either have to find a pump and repair the next neck on mine or try to find one that will work. Has anybody replaced one on a 342, and if so, what did you go with?
ALL IN AGAIN, 410 FV Twin 8.1 H/O MPI, V-Drives ,
https://www.amazon.com/attwood-500-GPH-Shower-Sump/dp/B0017QPTZM/ref=asc_df_B0017QPTZM/?tag=hyprod-20&linkCode=df0&hvadid=309807668151&hvpos=1o1&hvnetw=g&hvrand=7886116648712513014&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9015250&hvtargid=pla-568359096866&psc=1
https://www.amazon.com/gp/product/B07R6TZL5V/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I cut the mounting tabs off. Flattened out the mounting bracket on the right side a stewed it through the side of the box near the top. I didn't want the new box to hang by the clips holding the lid on. On the other side I just drilled into the top because it was pushing down on it. I'm just glad it works. Now to return the other one.
This is the one that works with a little work.
Attwood 4143-4 Shower Sump 750 https://www.amazon.com/dp/B001O0DECQ/ref=cm_sw_r_other_apa_i_tQ-aDbPR76Z3
