2003 342FV shower sump problems.
MojosBoatMojosBoat Member Posts: 102 ✭✭
Shower quit draining so I checked the sump and sure enough it was working. The pump is bad. Switch is good. Pulled the whole sump out and noticed the inlet neck is cracked. Went and bought a new sump from West mating. No good. It will not fit between the stringers. So now I either have to find a pump and repair the next neck on mine or try to find one that will work. Has anybody replaced one on a 342, and if so, what did you go with?
ALL IN AGAIN, 410 FV Twin 8.1 H/O MPI, V-Drives ,
