Sea water pump - longevity?
mattie
Member Posts: 1,255 ✭✭✭✭
Ours let go Sunday night. Pump shaft & pulley worked its way fwd. Threw the serpentine belt off. Immediate overheat, no power steering, etc. Belt demoed some other stuff.
Fourtunately only 1000ft from our dock. Got towed in.
I'm 3/4's handy, but there was no being prepared for that mech failure. Bit of a gong show.......
should be be good to go for Friday. Not sure if there is an expected lifespan for sea water pumps.
mattie
mattie
Thank goodness the failure was close to home. Pretty much only bathing suits & BudLight on board. I had no possible way of limping home. Tow was the only option.
They are replacing with factory OEM stuff. I looked at the Hardin, but I would imagine we will upgrade the boat in the next 2-3 yrs. Factory parts should suffice.
I've often thought about the saying above..........it's absolutely correct.
I had 13 years on my OEM pumps, replaced both with Hardin Marine SS pumps. The old ones were scored up, still working but were do.
A good question. I was told it should last 3 years ... and that was given running 50 to 100 hours per year. But I'm not sure if time also makes the impeller brittle ... so even if you don't run it??
By the way, the recommendation to replace it in 2 to 3 years is preventative maintenance. If may last 5 years, but I think someone has looked at the stats and determined the failure frequency starts increasing dramatically after 3 years. For such a cheap part, no point in taking the risk.
The life of the pump body depends entirely on how it's treated. If the only thing it ever pumps is clean fresh water with no debris, it could easily last 1000 hours or maybe much longer. If you run the motor with the intake sitting in sand, you could probably destroy a pump body in a few minutes.
I think most boaters that use there boat 75/100 hours per year change them every 3 for peace of mind.
why not going with the plastic housing and replace impeller every 2-3 seasons depending on use and conditions?
old applications used metal case pumps and now the trend is back again. I hear you can get 1 gal better per hour lol? That’s nothing.
