Steering Play - Rinker 260EC
I have a 2011 Rinker 260 Express Cruiser. I have a little bit of play in the steering, probably about a couple inches of steering before the drive actually turns. It's been like this since I bought the boat in 2011. Obviously, I don't expect it to be as reactive as car steering, but is this normal or is there an easy way to adjust the steering cable to tighten it up a bit? I do lube the steering cable every year. I had a Crownline boat with an Alpha drive prior to this boat and I don't remember that much play in the steering. I can't imagine something is seriously wrong as I only have 80 hours on the boat. Please advise??
Welcome to the RBOC.Sounds like you need to adjust the cable. Someone on this site will know and help you out. You can also search this site I think Babyboomer posted a link on cable adjustments. If he did I am sure he will chime in,
http://www.mercstuff.com/gimbalringwear.htm
Also Read This
http://www.boatered.com/forum/topic.asp?TOPIC_ID=127088
