Faria tachometer replacement
pearson57842
Member Posts: 31 ✭✭
My erratic Faria tachometers no longer respond to tapping on the face. I am looking for advise on replacement. My boat is a 2004 FV312. I have been following the thread on the Vesselview Mobile app and it looks like the module and cables, junction boxes needed for my boat would put total cost in the $600 range not counting the cost for the Mercury tech to reprogram the CityID on the port engine. A few questions for those of you that may have more knowledge than me:
1. Will the Bluetooth module work if mounted in the engine bay versus at the helm. Mercury’s response to this question was “it is better sending from a module mounted at the helm but you could try as I have heard of other people doing this.”
2. Has anyone found a non-Faria replacement that doesn’t require a lot of modifications to the helm.
3. Would I be better off just spending the extra money and installing Vesselview?
TIA.
TIA.
Reprogramming the city ID is a 5 minute exercise so it depends how good you get on with your local tech. I had mine assist on a couple of other things I was doing so a “hey, can you plug in for me and change this” wasn’t an issue. He actually plugged into he spare port on the jbox after and could use that versus the diagnostic port and see both at the same time.
