Fresh water won't pump to taps
                    Just bought Rinker 250v Fiesta
Can not figure out why I pump will not send to taps pump works and pulled line off at pump and it works then will pump to bilge under engine and will empty out the side of boat until tank is empty pump will continue to run
Any Ideas
Any Ideas
Does your pump run continuously or does it turn off automatically after a few minutes? If it runs continuously then you have a leak somewhere that's not allowing pressure to build up.
Lines will take a few seconds to pressurize before the pump stops, if there's no leaks. Yes, the hot water tank is pressurized via the fresh water tank and pump. So if the drain valve or PSV is open, it's going to simply fill up your bilge.
Are you saying that with the line attached to the pump, the water fills up in the bilge until your water tank is empty? If so, it means you're leaking water somewhere.
Any guidence on this is appreciated. My wife wants the running water badly for coking, cleaning, and showers. I understand that the toilet runs on a different system pulling in lake water to fill the bowl. I think...
Water flows through the hot water tank ... whether it's on or off. The only thing the water tank does is heat that water as it goes through it. On my previous 260EC hot water could be heated via shore power, or via engine (served to cool engine and heat up the hot water tank) while underway.
If boat isn't running and hot water 110V is off ... then you'll get flow through it, and cold water at the taps. Actually works exactly the same as your water heater in your home (except that might be gas if you are living in the North).
Mine was water from the lake. Through hull located basically under the mattress in mid-berth (under stairs). You should see a hose and valve, have a look.
Some systems need to be primed. Just fill the head with water using a bucket and flush a few times. See if that works to get the water going.
