350 mag won't stay running
Had a great day on the water today. Boat ran fine. Loaded it on the trail and brought it home to flush. Engine started fine , then after a few minutes it seemed to idle rough and early seemed to stay running, then a stall. First time in 9 years I had an issue. Went to restart. Turned the key ,heard the pump run for 5 seconds then start. Some fire but dies out. Looking for the obvious before I take it somewhere for service. Are there any driveway pointers I can try? First time the ol girl has let me down. 2004 350 mag MPI.
Brian
https://rinkerboats.vanillacommunities.com/discussion/comment/116645#Comment_116645
when they start to fail it happens over many cycles- the isolation material literally splits like a log through its axis... when heat allows the casing expansion enough, the isolation material comes apart and allows that beautiful spark exit (or enough ground found to weaken it's voltage, rendering it useless) but when it cools? varoom- it works again. until it expands (doesn't need much room to let the juice out) under heat it will work just fine. as soon as it expands it stops..
that^ makes it a trick to diagnose.
at some point, the coil finds enough ground to stop working altogether, not even allowing the engine to run (fire? yes... run? no)... and driving folks nuts trying to t/s it. unless they've seen it before... then, it's pretty obvious.
fat yellow wire, or coil. yellow wire just as if not more likely than the coil.
https://www.amazon.com/Mercruiser-2001-2004-392-863704-392-863704T-8M0054588/dp/B06XWDQRK7/ref=sr_1_3?keywords=2004+350+mag+MPI+coil&qid=1562856899&s=gateway&sr=8-3
but more importantly that that^, i hope the quoted price includes the lube and the parental prevention/protection from creepy crawly's.
https://www.wholesalemarine.com/mercruiser-ignition-coils/
Brian
