Fuel delivery
bhas15bhas15 Member Posts: 1
Hi everyone im new to this forum and the rinker family. I bought a great rinker fiesta vee 280 last year, Boat was and is spotless. The guy who owned it took very good care of it. I am now having a fuel delivery problem on my starboard motor.
1. Its way harder to start after sitting a few days unlike the port motor that just fires right up.
2. It will not always run on its seperate tank on the starboard side. I have to switch the middle valve to run off the port tank. Could this be a vent problem, fuel pickup problem?
3. I have a slight miss in one motor which i believe can be solved by cap, rotor and wires. Just want some other possibilities it could be. I only run rec fuel in the boat as well.
TIA for all your help.
  • LaReaLaRea Member, Moderator Posts: 7,973 mod
    Welcome to the forum!  Have you ruled out bad fuel, or water in the fuel filter?  What kind of fuel filter do you have?  If it's a spin-on filter that looks like an oil filter, remove it and dump the contents into a clear container to see how much water is in there.
    I agree with LaRea, start with fuel.
