Rinker boats good for salt water
Hello,
I'm looking to purchase a 2019/2020 Ringer 320 Express.  I noticed the company is in Indiana and it appears the majority of the boats are built for the lakes.  Can anyone give me the pro/con on getting a Rinker for salt water use?  I live in Orlando, Florida and plan to use it/indoor storage in a Cocoa Beach marina.  Thank you.
  • raybo3raybo3 Administrator Posts: 5,530 admin
    Blows away any SeaRay. Rinker is a great boat for fresh or salt water. I have a 2002 342FV. I keep it in salt water and zero problems caused by salt water.
    edited July 2019
    I think people argue what's a salt water boat based on the propulsion system.  Stern drives bad for salt water vs inboards vs outboards.  The reality is it's all about how you care for your boat and maintain all it's systems.
    I don't think the corrosion protection is as good as boats built for off shore but in hindsight I wouldnt buy another Rinker if I lived in Florida
  • aacrodaacrod Member Posts: 3
    Raybo3, what type of engines do you have?  I am still debating on Mercruiser or Volvo Penta with the saltwater protection.
  • Cableguy GregCableguy Greg Member Posts: 5,042 ✭✭✭✭✭
    The Ocean X seems to be a very solid drive. If I had a salty boat, I would seriously consider them. If I had a merc I would look at a bravo 1 or 2 drive because they tend to have less corrosion issues in salt water verses the bravo 3. If you are on a lift, then either manufacturer would be fine. Depending on where you are located, Volvo parts aren’t always easily available, which works in Mercs favor.
    Rinkers are "built for the lakes" and "built for the ocean." All boats suffer the effects of salt air and water. As others mention, special care is needed to fend off corrosion of the outdrives and electrical system. Dielectric grease helps with the latter. As Greg says, the Ocean X is a great drive and very corrosion resistant, however bottom paint does not last when applied to it so regular marine growth cleanings are a must. I've not noticed any hull or deck problems associated with salt water, and my boat has been sitting in it continuously for 13 years. My railings, through hulls and cleats look good as new.
    Andy.
    @andyd you said it all, maintenance. Non stop work. Always cleaning this, polishing that, fixing this. Never ends
    My dock mate winters in Florida and summer's here, has taken boats back and forth, he says the same... all about maintenance. There are boats in FL, all brands, that look like new thanks to TLC, and boats that look like crap, tons of corrosion, due to no TLC. Depends more on the owner than brand as for the most part the brands are all using the same engines and electronics and those are the variables.
    aacrod said:
    .raybo3 said: Raybo3, what type of engines do you have?  I am still debating on Mercruiser or Volvo Penta with the saltwater protection.
    I have Mercruiser. IMO and I do not mean to insult anyone but I would never buy Volvo Penta. I have seen way too many problems with them at my club and have heard many friends say they would never buy VP again.......... BTW my engines have been in salt water since the boat has been built. I the manifolds and risers just got replaced for the first time last season......... Just say'n
    Most boat builders that build boats intended for Salt water like fishing or cruising use higher grade materials and most are outboards or shaft drive. That's why they cost a small fortune.
    @Handymans342 Didn't you have Bravo 2's with your diesels?
    Yes Ray and they didnt have the corrosion issues that the B3s have. Dream has B2s also and has had a lot of breakage with them.
    So I wonder if you could get your diesels with VP drives.......
    Who cares. Bbahahahahahha
  • Dream_InnDream_Inn Member, Moderator Posts: 7,717 mod
    Two of my 3 "breakages" have been from hitting something solid.  Hard to blame the drives on that.
    Raybo, there is a 2006 390 on our dock that came with VP diesels.  Very nice boat and always well taken care of.
    What drives does he have??
    I did not ask my question correctly. Handy had Yan's (I believe) I was wondering if VP drives could fit those also.
    You can make any drive fit any motor with the proper adapter or whatever that is that bolts on the flywheel. What is your obsession with this Volvo thing @raybo3????
    Yanmar makes a great drive unit
  • PickleRickPickleRick Member Posts: 4,083 ✭✭✭✭✭
    edited July 2019
    VP has been matching diesels to the stern drives since at least the late 80s. The late 80s/early 90s volvo penta 290 could be bought as a sp or a dp.  They had different ratios for diesel and gas engines.
    It was a near bullet proof outdrive, still have one.  I believe to make it counter rotation you just flipped shifter cable. Was a great upgrade from the 280.
    I cant wait to get my hands on an om606 Mercedes diesel motor to marinize then drop it into my 235 rinker with a duo prop outdrive.
    Here are some Volvo-Penta drives I saw today, perfect condition!  :D
    Andy
