I have a 2004 fiesta vee 250... fuel breather fills with gas?
I cannot add fuel to my tank unless I disconnect the breather line and let it drain out the gas which gets in and place a piece of rubber hose over the metal piece on the tank and blow in to clear it..and only then will it accept additional gas..Anyone else have this problem?
Dave
https://www.westmarine.com/buy/west-marine--thru-hull-90-vent--15537145?recordNum=12
Andy
My vent boss was not kinked but had valleys in it. I re routed it so it was one continuous slope up hill. Problem solved.
I dont like the design of my fuel tank as all the fittings are right in front of the engine so it's easy to step on them and break something, I've aleady had to drill/tap fittings on my tank. I will be pulling the tank this winter and plan on replacing with something better designed.
