Bravo 3 losing oil
Lake_Bum
Member Posts: 1,073 ✭✭✭✭
So last year, I had a very slow leak, and determined it was a tiny crack on the reservoir. I topped off about 3 different times, a few ounces each instance. That was replaced this Spring, and I had two trips in, with NO leak whatsoever. Then a few days ago, I get an alarm beeping as I take off, I immediately stop, and check the reservoir, and it has gotten so low, I can now see the sensor in the bottom of it when I removed the cap!
I did verify it was full before this trip. I had no oil in the bilge, or visibly leaking into the lake. I topped it off, and finished out my trip, roughly 40 additional miles of boating. No movement on the full line on reservoir. I spoke to my mechanic today, and he said it probably just "burped". Not sure if I buy that or not...but I was given a fresh quart of drive oil for free to keep it topped off. I de-greased my bilge today, and plan on watching it VERY closely on the next trip. He did mention I could bring it in to have it pressure tested. Does that sound reasonable? Thank you....
Did you change the fuild in the drive this spring?
Roughly 30 hours this season, so far.
@McGarnicle - His mechanic says quart per season is normal
@rasbury - Never adds unless there is a leak
@Alswagg - Says 4-6 ounces per 50 hours of use
My mechanic was a cross between @rasbury and @Alswagg: I should not use more than a few of ounces and that would probably be from a "burp" early in the season after a fresh change of oil/service.
His advice was if more than half of the reservoir empties over the course of the season - or you need to top it off constantly - you have a leak and it should be investigated.
Speaking of oil usage - RE: engine oil - one thing I have done since the 90s was to remove the oil filters from my engines a couple of times a summer, replace them with a new oil filter and "top up" the oil. Of course, I heated the oil to operating temperature before removing the oil filters. I believe this practise was the cheapest way possible to ensure long engine life. I still followed Mercruiser break-in recomendation of oil and filter change at 20 hours and maximum 50 hours thereafter.
Back to the drives - drive oil changed every year or 50 hours maximum. Also every year pulled the B llls and replaced seals and checked engine alignment.
I have heard back from most of the owners of my past boats - some on their fifth owner - and all report extended lives of the equipment. IMO it's a lottttt cheaper to spend a little money up-front for greater longevity. :-)
Every year I change oil on motor, and drives, new impellor, and filters. This year I also did new plugs and wires, cap, rotor as well.
I will definitely keep a close eye on the level of drive oil. A 6 oz burp, should've been enough to fill any air pocket still in the lines. If I lose much more, I will get the boat into the shop right away for a pressure test.
When I bought the boat in 17, I went through new bellows, and serviced the entire drive, boots, seals, etc.
I was just stumped by the continued use of drive oil, that's why I posted.
