Some moisture in lube monitor.
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
as some may remember when I drained my stbd drive in feb I had some water, but found the vent screw on the drive was loose. Had tech vacuum and pressure test which came back good. Replaced all plug screws and washers with oem. I ran 1 qt of lube through to try to flush out water left. Cleaned out monitors well w spirts.
Now that I have 5 hours on this year I checked and found this. It really is very little but has me concerned. Could this be some residual from last year or a leak? Was thinking I’d suck this out, fill monitor with new and continue to watch it. The level has gone up 1/4” since launch but it’s also a lot hotter now than launch in early May.
I’m not afraid to pull the boat and have it re sealed but of course I’d rather do it this winter.
its just these two small lines in the corners that are white other side of monitor has no sign of moisture, it’s not piled up at the bottom.
deff need to check the drive out
I had asked him to check the port drive's gimbal bearing while its out as it was just starting to sound odd. He said water was in it from the bellow leaking and water was evident on the U joint/yoke (U joint is fine, just wet). He said the gimbal bearing which is only 18 months old is fine but he needs to confirm the leak and likely replace the bellow (which only has 2 seasons on it).
And of course one of my Lenco actuators was bad which I could tell as it didnt work so he is swapping that out for me.
fun fun.....
