2005 342 Gen and A/C
johnep
Member Posts: 114 ✭✭
I have had a week of break downs aboard. My y valve for the pump out broke, easy fix. But the Generator I just put a new carb and fuel pump on ran for around 20 hours and now starts and shuts right off. It did this before and the reason I replaced the carb. Seems odd it would clog up so soon. Over the last week the A/C seemed to struggle when the compressor engaged, today it pulls such a draw I have to shut it off or the fuse pops. I think being a 2005 it is time for a new A/C, but how often does one replace the generator?
thinking it’s probably a Kholer will
be expensive
fix it lol
As for the AC first check pump and thru hulls/lines for debris or corrosion. If ok then taking a pressure reading, checking the capacitor(s) is a good next step. Usually a bad compressor means time for a new unit. Id imagine it runs off of the same principals as a heat pump or home AC. Im no ac expert, they run on voodoo. I know enough to keep my home heat pump going.
Or again, sell and buy new! Us budget guys like a deal!!!
On the AC I've heard of a couple of cases in our marina where the breaker gets thrown when the compressor kicks on. In their cases it was the capacitor on the AC. Of course could always be a bad breaker. The AC in a 342 is super easy to access and I've seen guys buy the unit for under $1500 themselves and toss it in. Lots of info on this site about that.
Come to think of it ive seen bad wiring trip breakers as well. Usually the wire is extremely hot to the touch when it's the culprit.
Oh, and I agree with Liberty. The AC can be had for under $2k and an easy install. I agree with not messing with that and just replacing. The new AC units are much quieter and don't rust.
As for the AC, likely the one you have is obsolete on parts. Mine was. Super easy to remove install yourself, if you are handy that way. Save yourself $1k+! I’m pretty OCD about that stuff, maybe a couple hours for the whole job done OCD correct. lol
Great minds think alike!
