Coming off of Plane
raybo3
Administrator Posts: 5,586 admin
So in an other thread @reneechris14 say's "note to self come off plane slowly". So question is, how does people come off of plane? Here is what I do. #1 make sure drives are fully down. #2 I lower my trim tabs. #3 I slow down a little one engine at a time. Kind of a back and forth between the 2 until boat is off of plane. #4 raise tabs back up or boat will not reverse....lol. Now I will be curious to see who else does this.........BTW this is to prevent water from coming over the swimplatform and to prevent water from going into the bilge.
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Since my buddy lost both motors due to water inversion (failed flappers allowing water to enter) I pay very close attention to coming off plane. Although, unlike his SeaRay, my Rinker 300 does not seem to squat in the manner his does allowing a flood of water to enter cockpit up and over swim platform.
My method is to make sure both drives are in full down position, then tabs fully down. As @raybo3 states, this makes the bow dig in more and brings the stern up and level. Then slowly bring both throttles back (simultaneously). Only in an emergency would I ever pull back quickly; and even then I would burp throttles forward just before the rush of water approached the transom/swim platform. My belief is that this method will keep the rush of water from coming into the exhaust bellows, and eventually entering manifolds, and your cylinders.
I do not see any advantage to bring the throttles back 1 at a time; would cause port/starboard listing I presume. But if that works for you more power to you!
You just triggered my memory, I saw that video also.
https://youtu.be/L1SZiMJ0vx8
https://www.boatus.com/magazine/2014/june/staying-in-trim.asp
Edit: and I'll add, even the slightest bit of drive up will cause this. May be partly because I tend to run with full fuel and water most of the time. Once on plane, tabs up and she just floats along nice, my usual cruise is 24mph at 3400 RPM.
