And the hits keep coming
Had a less than fun weekend. Decided to head out Saturday afternoon. We got out of the canal and tried to get on plane but could not. Tried 3 times and gave up and headed back home. As we got close to the dock I shifted to neutral to further slow down. I applied reverse but noticed I wasn't slowing much. I applied more reverse and lunged forward into our seawall. The boat wedged on a post at the seawall. The shifters were in neutral at this point but the boat was stuck good. Had to turn off the engines to un-wedge the boat.
Next day went and tried the engines/shifters. Starboard works as it should. Port is stuck in forward.
So back to the shop we go.
Yes there were flakes of gelcoat in the water after the impact.
No this was port side. Starboard is the engine that was just replaced.
Another story to reminisce about when you get to an old age home.
The second time it happened, I knew right away that I had to cut the engines.
pulled in and noticed idle rpm was little
high in gear.
threw it in reverse to slow down
put her back in forward and gave gas to steer in.
let’s just say she was still in reverse lol
cable separated right at the arm and caused me to crash into the dock and another boat.
