Weak bilge pump
I went to go pump out a little water in my bilge and my pump seems to work fine and suck up water but it wont push it out. I pulled the hose to see if it was clogged and its wide open. Do these pumps lose power over time? I bought a new one but curious if it could be a different issue.
Also Rule 1100 gph 27D looks to be discontinued which is what I have now. In efforts to not have to screw new holes, has anyone replaced with the 27DA and know if the holes line up?
As always, thanks for the help.
Patrick
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
I don't pump out much, if any at all. Actually, it gets most use when I clean the bilge (which is quite often).
