Dexron ATF or Power Steering Fluid?
Willhound
Member Posts: 4,224 ✭✭✭✭✭
Noticed my steering was a little notchy at low RPM's when out the other day. Going to check my fluid when I get back there tomorrow and want to bring fluid just in case. Would have thought just Power steering fluid, but a checkof theMercruiser manual posted in the archive section shows Dexron or Dexron II ATF fluid?
Go with the manual I guess???
Ditto on atf for me too. Also use it in my trim tabs so i keep it on board
How much greater??? I don't know. I've never seen a pressure gauge on power steering set up lol.
If it's 10 psi more, probably not noticeable. 50 psi more, might eventually blow a seal in your ram as those power steering hoses are stout. 100+ psi more, you'd have already noticed an issue.
Like i said, if it's been working for you keep at it!
