Stern Anchor
aero3113aero3113 Member Posts: 9,623 ✭✭✭✭✭
There was a 13 lb. stern anchor in the stern locker on our 330. Is this the correct size? It seems a little over kill to me. What do you guys use for the larger boats?
    I have a Fortress FX-11 as a stern on our 342.  I've used it by itself when it's not too ugly in the bay.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,845 mod
    Can't ever be oversized.  I've been in some sterns where the wind ends up on our stern and was glad I had an extremely oversized stern anchor.
  • PickleRickPickleRick Member Posts: 4,274 ✭✭✭✭✭
    I have a 3 ft deep scew in anchor to tie my stern off in the sand and I've had wind/wakeboard boat waves yank it out.  My boat is only 23 ft long and i have a bimini instead of an enclosure.  Id say you can never have over kill unless its because of a lack of storage space or inability to physical pull it up.  Whatever anchor a manufacturer recommends, go up one size!  Whatever chain they recommend go longer and larger if capable. Same same with length of anchor rode(rope for you power boaters😜) A dragging anchor at the every least is an inconvenience,  at its worst a collision.
    Agree with dream, can’t be too big and that size is fine, when the wind shifts to the rear you don’t want it to pull out forcing you to re set and or break up your raft
    This summer I upgraded our stern anchor to a 13lb folding grapnel anchor made by Extreme Max. All over Ebay.
    About 6ft of chain rode & 50ft of proper anchor line.
    Holds perfectly - every time, 32 ft boat 9'8" beam.
