Odor from holding tank
Looking for recommendations on how to reduce or eliminate the odor experienced from vents on port side of stern. This occurs each time the head is flushed.
    Install a big orange. Search online. It doesn't cost much and takes 15 minutes to install. Problem solved for good.
    Hi, There is also a thread on this forum how to make one yourself. I did and it work perfectly .
    l-skynyrdl-skynyrd Member Posts: 178 ✭✭✭
    Just another thought, I use a powder call    noflex digestor  and it eliminates the odor at the tank,
    Big Orange eliminates the odor but not at the tank. Been using it since last summer, works great.
    There is a thread on here you can search "noflex" with more info.
    Big Orange.  Way to go.  Never had an odor since installing it two years ago.  2 minute charcoal change if you get it wet (overfill) or routine change every year or two.
    Gary and Diane
    290 FV Nauti Bonnie
