Lower end unit oil change.
PitterPatter
Member Posts: 23 ✭
Has anyone every used thier oil extractor to drain the oil from thier lower unit? I'm on a lift and this would make oil changes much easier. Just curious if there is a reason why this cannot be done.
I actually pour what I can out of the reservoir before draining. Just that much less I have to wait to trickle out of the drive. Also make sure to get a good cleaning in the reservoir.
Actually, they are quite large and float very well. & I'm very consciousness about not getting any drops anywhere but in the pan. Where I keep my boat is basically in a large pond (where entrance/exit is thru a 20ft wide opening under a bridge), so it is very calm. I sit on the raft and with a remote for my lift, I keep the skegs holding the pans in place (I also hold them as I need to). It is usually a good time for me to wax my drives and do a cleaning while monitoring the oil draining.
Carry a small jetski looking sealed battery with me and my positive wire has an on off switch. Alligator clips for quick disconnect. I use a jon boat to do my on water service in so if my bucket spills i catch it in my aluminum hull.
The viscosity of 90w isn't far off from 40wt.
That pump is for diesel too and diesel isnt too far from 30wt viscosity. I dont see it having an issue. If you're pumping in extreme cold temps just put your new foot oil in the house over night before the change.
Before i got the electric pump i used the red top kerosene hand transfer pumps to put oil into diffs and transmissions/transfer cases.
