Motor Mount Lag Bolts
I likely will be buying a 2005 270 this week. One item of concern, on a couple of motor mounts it looks like they have moved as the lag bolts are not vertical.
How much of a concern is this. The boat has the 496, so with the small lag bolts it's not surprising they have moved.
I plan to check to ensure the wood is not stripped (put a wrench on the lag bolt and ensure they are snug), and check for stringer rot. If I buy the boat, I assume an immediate alignment check would be wise.
Looking at the pics, any major concerns you see? Looks very clean for a 15 year old boat.
Thanks,
Jim
Thanks,
Jim
Also, the pucks look tight. If there was movement I would expect you'd see some discoloration or marks at the puck?
the angle those are set in the picture sure appears to me that the engine was set in and the lags driven in with the engine in place.
you've gotta figure the lags aren't pulled 'up' without pushing down on the other side during revs/torque. you've gotta further figure the rear mounts maintain the alignment on both sides and then vertically as well. i just don't see how a lag, properly installed, and without a broken mount either above it or the other side, can 'pull' a lag like that.
little stuff like that irritates me. it could have been done right. it wasn't.
