Can someone verify some dp c and e gear ratios for me?
PickleRick
Member Posts: 4,274 ✭✭✭✭✭
I am getting conflicting info, im needing to be able to prop a 23 to 25 ft hull for approx 25 to 30 knots at 3400 to 3700 rpms.
The aq series (280 and 290) offered diesel gearing in both a 1.95 and 2.3. Ratios. These also fit on some gasser 4 bangers, v6 and even some v8s depending on applications.
These were 80s to mid 90s vintage.
For my application lower the rpms the better.
I know the vp site used to list this info but the page is dead now. Also, go pens
I needed real world info not just paper calculations. Exactly what i needed
Im acually not allowed to open up a chainsaw or weedeater L or H fuel adjustment screws further than stock specs. It's an EPA fine if reported. Been that way for years now.
South Carolina has not done any inspections since the early 90s
With either engine 4000 or so rpms is safe for extended periods of time. The yanmar from the BMW also found in marine applications.
