Battery Recommendations
In need of a new house battery. Current battery (came with boat) is a West Marine (WM) Model 15020191 which is a Group 27, Dual-Purpose, Lead Acid Flooded, 650 CCA, 800 MCA, 150 RM. (Current price is $179.99.)
Before anyone suggests going to Gel, AG, etc., please note I would love to if money was no object, but my two starting batteries are in great shape, and since I have a Progressive Dynamics PD2130 charger -- you cannot mix and match battery types. It's all or nothing when you profile the charger. So, instead of having to spend $700+ for three new high tech batteries, I'm opting to spend less to go with another legacy LA and use the savings on other projects.
Now, since I can go with either Group 27 or 31 -- what brand/size do you all recommend for a good deep cycle LA battery?
Looking at the West Marine Deep Cycle choices...
The Group 27 has 575 CCA, 705 MCA, 175 RM. $199.99
The Group 31 has 650 CCA, 800 MCA, 185 RM. $279.99
Or do I just get another, same model Dual-Purpose for $179.99?
Any other options good out there?
Sooooo - better specs as the West Marine but $130 cheaper. Thanks for the tip!
Previous owner had really expensive 31 AGM's (house & dual purpose) installed. Dealer told me most of the batt failures they run into were AGM's vs battery charging systems. Something doesn't work quite right long term.
Nice thing about winter layup, no rush to purchase
Thanks!
Main reason I'm sticking with LA.
I completely agree. If you don't have the correct chargers for the batteries you are using, you will not get the performance that is spec'd.
This is the first time that I went all out and got 2 starting AGM and 2 AGM TPPL house batteries (Northstar from WM). I had purchased a charger that is spec'd to charge these batteries and so far I have nothing but excellent results. Starting batteries, well, can't judge much there except they start the engine just fine. But, I really use the heck out of house batteries and I am on the hook a lot. So, I am fine using my generator, but like to cycle my batteries down to almost 50% (12.2V) each time. I can go a full 12 hours with 2 fridges running and normal use of radio and whatever else throughout the day.
Now, on that note, I used to use the Walmart batteries with great success too. They also lasted me 5-6 years and if I turned the fridges down at night, it was no problem getting 8-10 hours before having to start genny. It all depends on your needs and use.
You are doing it correct in that you will install new batteries fresh in the spring after doing research thru winter. I'll add that the Walmart 2 year warranty is really nice as well if there are any issues at all. I had an issue with one of my batteries at the beginning of the 2nd spring and took both batteries back. I explained they were connected in parallel and need to be the same age, they gave me 2 new ones. Good luck!
I've got the PD2130 charger from Progressive Dynamics as well. Very clear instructions on specific settings for batt type. Imagine this isn't getting addressed by most boat owners.
Tech at the dealership figured most of the failures were from over charging GEL & AGM's. End up junk after a season or two. From the PD manual it shows the float/storage should only be 12.8V for GEL & AGM.
Lead-Acid Batteries
BOOST = 14.4 V, NORMAL = 13.9 V, STORAGE = 13.3 V
GEL-CELL & AGM Batteries
BOOST = 13.9 V, NORMAL = 13.3 V, STORAGE = 12.8 V
It is typically when not on load. I try to look at it when the fridges have kicked off.
