Through Hull Ball Valve
I went to cycle the through hull valve for the generator and the shaft the handle is on broke off! I would rather it break now then in the water when needed. Why did Rinker use a valve with the triangle flange? Is there any reason why I can’t replace it with one without the triangle on it? Also, the 1 on the valve, I’m assuming that it’s a 1 inch valve?
Permatex 80631 Thread Sealant with PTFE, 1 oz. https://www.amazon.com/dp/B000BKEBT0/ref=cm_sw_r_cp_api_i_6mXZDbYCYNSB4
