Fuel pressure tester
frenchship
Member Posts: 1,079 ✭✭✭
Hi,
Would anybody know if this fuel pressure tester would work with Mercruiser 5.0 MPI ? It has the GM adapter for the shreader valve.
Thanks
Paul
if you're permanently mounting it, I'd get a look at the hoses first, and make sure they are compatible with gasoline AND high pressure (such as found in fuel injection hoses).. Goodyear makes a hose that is compatible and will operate in the pressure ranges- it has a blue colored interior lining... It's not cheap as far as hoses go, but it's a lot cheaper than having a rupture and spraying fuel everywhere and the implications of such..
A lot of folks will intercept the cross over hose and snag a reading from there (most often, these rails don't have schreader valves; the majority of the components in your picture are related to this approach)... they don't think to use qualified hose, and use el cheapo hoses provided in most kits. that is a bad idea. do yourself a favor, especially if you plan on mounting this thing as a permanent fixture and use the goodyear hoses. If you're just using it as a diagnostic tool, you'll be fine with just the gauge, and the short hose to the fitting..
