Iac filter
rasbury
Member Posts: 8,740 ✭✭✭✭✭
2006 350 mpi- pulled the aresstor to clean it and to change the filter- I don't see one or where one to go? I have two hoses that come from the side of the intake/butterfly that go to what I assume is the iac mounted a few inches back from the intake towards the transom, just don't anywhere for one to go even if mine were missing?
https://youtu.be/RLbOE1mkXVw
While I want to make sure my setup is correct I really don't have an issue with idling hunting. my issue is more when I'm under way and I give it the gas and it starts to sputter and spit it was firing back and all kinds of stuff. I assumed it was from sitting so long and bad fuel but I have run it out. sometimes it does it, sometimes it does not. I'm on the water today and it ran pretty good. But I was plaining out running across the lake and it started to cut back a little on power. It might just be time for a new wires and plugs. I'm at 300 hours I put one set of plugged in when I first got it but I'm on the same set of wires I started with. I put all new filters in...it is not back firing any more and I did clean out the arrestor...
