Mid bilge stringer issue
Pat310
Member Posts: 596 ✭✭✭
during the survey of my 2003 FV 310 last summer, there was some exposed wood in the mid bilge and about an inch of water.
The fiberglass is missing from the inside of the half round hole exposing the wood to the water
It uses waterproof outdoor grade glue. It has more voids than your marine ply at 20% of the cost. Epoxy bonds a good 30 to 40% better mechanically and chemically than the vinylester resin used in the original construction.
Thus it will never rot again in your life time so long as you properly seal any scew holes.
Drill all planned scew holes out to about 3/8, fill with thickened epoxy resin.
Once cured drill your pilot hole for mounting scew. Install with 4200 or life calk.
Ta-da.
