FUEL COOL- FUEL MODULE 5.7 Alpha One
Any mechanics here explain how the fuel cool system works on this model? You have a manual fuel pump along with this fuel cool module? A new one of these modules is over 1200 hundred dollars. This is 97 5.7 Alpha One gen 2 Merc. Is there a filter on this system?
If it were me I'd delete it. There are some cases in an efi system where the fuel doesn't return to the tank but in a carbureted engine i see zero use for it. Even if i did have an efi system id put a fuel line return back to the tank before id put 1200 in a fuel cooler.
I boat in South Carolina. We've had 90 degree water for weeks, day time temps in the upper 90s for up to two weeks, lows over night in the 80s during that stretch. I never once had an issue with the carb. I ran the near identical carb as my rinker(auto version) in my old land cruiser with a 305 for about 3 years. Again, no return and no fuel cooler. She was properly tuned and timed, that carb didn't care if it was 9 degrees or 99 degrees. Still got better mpgs than the original Toyota F series inline 6 that came in her...didnt get near as good of fuel mileage as a diesel but that's another argument all together.
Im running a Charles bridges built holly marine 4bbl and new carter mechanical marine fuel pump on my 5.7 mercrusier.
The fuel coolers i see take in lake water, around here the lake water is 80 plus degrees from June til October. Colder up to joccassee but i don't swim or boat in cold water. Many times i go to the keys and the water in June is colder than the lake temps when i get back home.
Yes you have a fuel filter. Mine is starboard side, looks like an oil filter. Sits at the front of the engine opposite the alternator.
I wonder when they changed number on those filters? Strange that on bottom of old filter it has the number A031197 WI. I hope that don't mean 11/97. That'
