how does this work electrical
My job is really starting to impede my progress here..... From the survey, the winless does not work and the spotlight on the front light is out, rotates but no light. Also, I think the ship to shore does not come on but have not messed with that yet but the first think I went looking for is a fuse- I only see breakers and I don't see any way to inspect them? I'm surmising that if something pops, those little center things will pop out and you can push them back in to re set. I've not used anything like this.....back in the batter switch area there is one for the winless and it does not appear to be popped out any further than the others so I'm pulling the windless switch to see where I lose power. Are there any other fuses I can't see access to easily or is that it? Any common issues with Horizon brand?
Ray
2006 390
Previous 2000 340
Parts manual: http://www.ourcayoloco.com/docs/TP5987.pdfInstallation manual: http://www.ourcayoloco.com/docs/TP5982.pdfOperation manual: http://www.ourcayoloco.com/docs/TP5985.pdf
