replacement carpet
I recently bought a 01 242 that's missing the snap in carpet. I was wondering if you guys could point me in the right direction. Thanks I've been lurking for a while and learning a lot from the veterans very knowledgeable site thanks
  • golfdoggolfdog Member Posts: 151 ✭✭✭
     I agree with RinkerYan.
     I bought a replacement cockpit carpet from snapincarpet and am very satisfied.
     If your lucky they will have a pattern of your boat.
    Jerry
  • Dream_InnDream_Inn Member, Moderator Posts: 7,712 mod
    Yes, I've used Snapincarpet as well with good luck.  You could also check locally just as a comparison.  I know others in my area that have had good results doing it that way as well.
  • NicknightrodNicknightrod Member Posts: 2
    I contacted snap in carpet unfortunately no pattern so I'm sending them the measurements does anybody know what it usually cost for replace
    Take your old to a local carpet store they do good work and your supporting your local economy I did and am very satisfied used marine carpet no rubber back it dries a lot quicker
  • Cableguy GregCableguy Greg Member Posts: 5,039 ✭✭✭✭✭
    Try Rinker. They might have the pattern for the boat.
    edited March 2014
    You can use the old carpet or make a paper template. Snapincarpet is great to work with. If you go with them, get the grey backed carpet, not the black waffle backing.
  • Capt RonCapt Ron Member Posts: 217 ✭✭✭
    I'm with Baby Boomer, go locally and bring your old carpet. Go with a high quality 100% Nylon and never look back... any carpet store worth their salt can cut and bind any carpet... going to boat stores usually has a marine cost to the carpet with mediocre carpets.
