Anchor Locker Drain
My anchor locker has one drain on the starboard side. There is a molded indentation on the port side that I am considering putting in another drain. I have two options for this new drain. First is to drill another thru hull on the port side of the boat. That is the easiest way to go about doing this, but I would have to match the location on the port side with the one on the starboard side. The second option would be to put the new drain in with a 90* fitting, then put a 'T' below the existing drain and let both drain out the existing thru hull. One less hole in the side of the boat and I wouldn't have to match the location. I am leaning towards the 90 and T.
