Battery Charger
I am beginning to think that my battery charger has seen better days. Went to the boat today to divert my leak and take down the frame for the winter cover and ran my portable genny to charge the batteries. I open the hatch so I could remove one of the house batteries to bring home to do a full slow charge and the on board charger was reading "Full Charge". When I went to the cabin and shut off the charger breaker, all of the lights went out. That was telling me that the charger was giving a false reading. I have the original Progressive Dynamics dual battery charger on board. If I replace the charger, should I go with the new version of the PD charger or go another route? Thoughts???
I'm not sure that it does. I know that has similar setup to you and just charges them all at the lower levels (Lead battery). I would not recommend doing that because I don't think he gets as good charge. (This is Pau Hana - Glen - & when we compare while anchoring, I don't think his last as long. He has identical batteries to mine, & of course same boat).
I'd recommend getting a new starter AGM battery if possible. The promariner nautic charger is, to me, the best out there. Well worth using.
I installed this over the weekend, i hard wired it as i didnt want to buy the quick disconnect plug. It has standard color code shield power wiring inside black insulation.
I realize this voids warranty for some reason but with the positive reviews and simplicity of wiring i wasn't worried about botching the install.
I recommend smaller independent battery shops, ask them what brand/type they'd use in their boats. They know batteries and can answer all charging/tech questions.
If you're in a marina/boat club see if you can generate a group buy for possible discount. Most of you guys need new lawn mower batteries this time of year as well.
My local indy guy delivers to me free of charge and gets my cores. Will also buy my old junk cores.
On our 2014, the orig batts were Interstate lead acid. In 2017 previous owner switched them all over to AGM's. We bought the boat in late summer 2018.
Long story short, previous owner didn't revise the charger settings, AGM's were toast.
Last spring, I went back to all lead acid. Dealer recommendation.
All comes down to care for the equipment. Absolutely nothing wrong with LA batts if you take care of them. And no, I wouldn't mix batt types - might get away with it for a while.....but.
Curious to know what you figure out. Keep us posted. Sleuth something out - makes for good COVID reading.
I love messing with stuff, big on preventative maintenance as most forum members are. Sometimes I torpedo myself by over doing the preventative - makes the situation worse - before it gets better. lol.
I believe so. It would show full charge on batteries that were not fully charged.
