2000 270 fiesta vee shower sump access
whats the best way to access the shower sump on a 2000 270? There is a small access hole under the rear mattress but it is not really servicable through that small access hole. Looks like removing the steps might work. Can anybody outline the process to remove the steps? Thanks.
As much as it's difficult to get at, you can certainly service that sump from that little access hole. I've had mine completely out twice, once to clean and once to change the pump. Was not that difficult. Certainly much easier than tearing out structure.
Personally I'd rather remove mechanical components like the AC pump and not mess with structure, but that's me.
i found by taking aft mattress out to lay in there while working behind the stairs...in that space worked best for me
i had no problems removing/installing shower sump
