Airmar h-27 thru Hull speedo
noidea44
Member Posts: 14 ✭
Today, I was was under my 246 painting the bottom and noticed the airmar thru hull speedo is wet around the edges. Is this common for the seal to fail? Can I unscrew the nut inside the boat and remove fitting to re-silicone or does it need to be replaced?
If there's water leaking out from the seal, that's bad. Water has penetrated into the hull. Remove and re-bed the sensor at a minimum.
it poured here and this morning there was water in the bilge mixed with some antifreeze that I accidentally spilled in the bilge before it was wrapped last year. This was most likely seeping since last year. And just noticed today.
